- Mute
- Permalink
- Report
@atomkinder67 wrote:
What does it need to be? Plain old G03? If G03 will work go to about line 1331 and you should see this:
writeBlock(gAbsIncModal.format(90), gMotionModal.format(clockwise ? 2.4 : 3.4), xOutput.format(ip.x), yOutput.format(ip.y), zOutput.format(ip.z));
and change it to this:
writeBlock(gAbsIncModal.format(90), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(ip.x), yOutput.format(ip.y), zOutput.format(ip.z));
And see if that solves the issue. This is a 3D arc though so it may pay to simply linearize it, or turn off vertical lead-ins.
I tried the change. It just linearize it.
I think this is what I want. Not sure where it needs to go or if I need all of it.
} else if (!properties.useRadius) {
switch (getCircularPlane()) {
case PLANE_XY:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
Fusion
