@atomkinder67 wrote:
The only time I think this would be useful would be if you are using the same tool for multiple features that aretolerancedunidirectionally in opposite directions.
I ran a machine with stock to leave only for tolerance compensation for years.
Now I use both, because just the cutter comp only on the machine won't work for milling. You need so many different tolerances with the same tool that usually it's a good habit to use the stock to leave boxes to make the toolpath mill at the middle of the tolerance you get. I mean you can't use cutter comp to mill a +/- 0.02 mm and a -0.05 - -0.10 mm tolerance so if you make sure the first tolerance has no stock to leave and the second one has -0.0375(Since usually doubled since on two sides) adjustment on the machine should be correct for both tolerances.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
