ProteumMachining
You can also duplicate your tool and just set a different tool diameter offset number for just that operation or feature. That way you can still use the wear comp in your machine to work up to any tolerance you have. I tend to stay away from using "stock to leave" as cutter comp as it starts stacking up and getting confusing when you have multiple dimensions and features you are trying to comp in.
