622 Views, 5 Replies
Using "Stock to Leave" instead of cutter compensation
Thought I'd share this as I just discovered it yesterday (seems like a no brainer now!).  Instead of adjusting for cutter comp in your control/machine you can alternatively use the Stock to Leave function under "Passes" tab.  This should give you more control of a single tool over multiple features.
