jgaertner
316 Views, 2 Replies
Chamfer command cutting a V groove?
Hello Form,
I need help with a very simple chamfer I want to cut on two edges of a flat plate. When I simulate the operation the model looks like the chamfer tool is cutting a groove along the edge not knocking the corner off, like I want? No idea why its not working. I even tried copy and pasting a chamfer op from another part that I know works. Same thing on
this new part. I am missing some setting. Thank you. Jgaertner
Richard.stubley
in reply to: jgaertner
Firstly thank you for uploading the F3d makes life so much easier.
You contour selection is the wrong side of the line for what you want. We do our best guess but sometimes get it wrong. Just click the arrow to change the side of the line we cut.
Richard Stubley
Product Manager - Fusion Mechanical Design
jgaertner
in reply to: Richard.stubley
Thanks! I knew I was doing something wrong because the operation had worked on other parts I made recently. I appreciate your help! Jgaertner
