03-06-2020
10:02 AM
- Mute
- Permalink
- Report
03-06-2020
10:02 AM
For the post error, it means your post is not setup to handle "air" as coolant. If you need air on your tool you need to get that worked out in your post. If you don't need air, turn the coolant off or use another type of coolant that you post supports. You might have a coolant section in your post that looks like below, maybe you can edit it to make it work yourself. But I think there are a few different ways to deal with coolant in various posts, so i'm not an expert for this, just pointing you in a direction in case your post is like this one below.
Fusion
