01-20-2016
11:35 AM
- Mute
- Permalink
- Report
01-20-2016
11:35 AM
OK Adam,
I selected the model and used Mark's idea of drawing a line to do the roughing pass and then a rectangle as a boundary to contain the operation. Then I watched your screen cast and figured out that you are using the <Alt> key to select individual edges to create the chain that you want to machine. I hadn't seen that trick before. I guess I really need to go back and watch all of the training videos.
I have the 3d operation on the 1/2 round working now. Now I need to see if I can get the slot cut on the rod. I may just sketch the path I want the tool to follow.
Thanks to both of you for your help.
Chris
Fusion
