sitoru
329 Views, 2 Replies
Can't figure out how to get rest machining to not skip certain areas
I've been trying to figure this out for a couple of days, but this is as close as I've gotten.  I'm doing an 3d pocket clearing with a 1/8 end mill which gives the correct result. But when I try rest machining it skips certain areas. I'm choosing a .1mm v bit so it does fit in the area. I've messed a bit with the cusps, but the wrong setting seems to select the whole model to machine.  I'm still messing with it, but for some reason fusion is slow for me right now doing the calculations. Screen Shot 2020-02-10 at 8.12.25 PM.pngScreen Shot 2020-02-10 at 10.24.20 PM.pngScreen Shot 2020-02-10 at 10.24.45 PM.png
