Chris,
I remodel your bottom jaw and I didn't have to select the model in the setup section.  I still got the parallel toolpath to work.  Edit: But since your model is a quazi assembly, I think Cam doesn't know which body you want to machine so you have to select the model in the setup section.
I attached my model if you care to look it over but it's just one model and missing the top clamp.  Therefore, I didn't need to select in the setup section.
Mark
