Steinwerks
First thing to EVER do in CAM: add your Model to the Setup.
Next, you have to define the part of your part that you wish to machine. I've attached your part with a new setup. I modified your original 2D Contour to be a little nicer on the tool, added a contour to cut the ends, and a Parallel toolpath to cut your slot. There are a good number of parameters to play with but this will work. You'll have to figure out what the best stepover/stepdowns are, and the correct feeds and speeds for the material and your machine obviously.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
