It usually is whithin the power of the fancy CAD/CAM tools but it can be frustrating at times.  But I hear ya!
I had trouble doing this on your part so I drew a new model and extruded a circle to make the cut you're looking for.  It worked on my model so maybe look back at your modeling methods so see if something is affecting that surface you want to machine.
See the attached image (of my remodel) with a Parallel toolpath found under the 3D dropdown menu.  My model has a sketch that acts as a bounding box for containing the tool.  Your stepover amounts may need to be made smaller because the .250" ball mill takes up a lot of room in your grove diameter of .312.  Again, I hope it helps ya.
Mark
