Hi Chris,
Go back to your model and add a workplane tangent to the bottom of the groove, or use an offset workplane.  Draw a line on that workplane to act as a path you want a tool to follow.  Return to Cam and use the Trace toolpath (I couldn't get this to worlk with Engraving so use Trace).  Select the line you drew when in the the Geometry tab.  In the Passes Tab, checkbox Axial Offset Passes to control your depth of cut/# of passes.  See the attached images and I hope it helps.
Mark
