02-05-2020
06:37 AM
- Mute
- Permalink
- Report
02-05-2020
06:37 AM
As far as I can see it works as before. It is a bit clumsy and we have plans to improve it.
Steps:
- Create a new probing operation
- Click the wall you want to probe approximately at the position where you want the mid-point of your probing to be. Don't be put off by the fact that the operation will be created at the center of the wall.
- Check the Use Selection Point box. The operation should move to your desired location in one axis - in my example it is X.
- Use the Spacing and Bottom Height parameters to make sure that the probes are hitting the locations you need in other two axis.
Fusion
