3294 Views, 18 Replies
Milling a half round groove and using a slitting saw
Hi Guys,
I could use some CAM help. I have a project where I am cutting a 1/16" wide slot down the length of a 5/16" aluminum rod. I designed a fixture with a half round groove on top and a matching clamp block. I want to use a 1/4" ball mill to cut the groove. I tried every CAM option I could to mill the half round groove but Fusion wwouldn't let me select the face of the groove to mill.
The second issue I had was cutting the slot in the rod. I'm using a 2.75" x .063" slitting saw. The slot doesn't run the entire length of the rod, only about 80% so I designed it with a 2.75" radius at the ends so the saw could ramp into the slot.
Can any of you get this to work?
Thanks!
Chris
