panscan
622 Views, 5 Replies
4axis Milling simple crank
Is  there a way to 4axis mill this part in fusion. I would like to use a tool thats close the the tapwith and rotate the 4th axis and just follow the shape down since 2 taps are offcenter. I dont like the 2 piece patch way. would it be possible to step down in in Z the flow strategy ?
Or how would you do it when using 4th axis.
Attached are a screetshot and fusion file of the example.
