01-20-2020
06:35 PM
- Mute
- Permalink
- Report
01-20-2020
06:35 PM
What type of machine are you using and can it handle a depth greater than 1mm?
You say 3 to 4 hours is this real-world or what fusion shows?
You can have the retract hight set to 1mm if there is nothing inside the area being cut higher than 1 mm.
You can have the clearances hight set to a depth where it will clear any object on the table if there is nothing higher than 10 mm set it to 11mm.
Having maximum roughing stepdown and fine stepdown can help a lot in some cases.
I am trying a few things I will post back soon
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
