- Mute
- Permalink
- Report
Have you tried setting the tolerance and smoothing values higher, especially the smoothing tolerance, the lower the value like your 0.0004 will result in many very tiny A axis moves.
Try setting the "High Feedrate Mode" to "Always use high feedrate" and input a value of say 5000, in theory if that value is equal or higher than the max speed for the A axis in your control it will in effect go to your Rapid for that axis.
Now try setting the main "Tolerance" value to 0.23 and your "Smoothing tolerance" to 1.0 and you should get a single high speed move from one side to the other, I tried it out on your file but as I don`t know what PP you are using I just had to use a "Generic" one so the code is probably not exactly right.
However what I did get were moves from
A-50.112 G94 X0. (This is the cut back to the front X0 point)
G93 X-0.0236 A-48.553 (Leadout move one)
A-50.112 (Leadoutmove two)
G94 Z1.556 F5000. (Rapid out in the Z)
G93 A47.771 (Now moved to a + position in one move)
G94 Z1.0079 F5000. (Rapid back in to leadin position)
May work for you, not pretty for sure but a workaround of sorts, I left the feed speeds out as they would probably not be relevant !!
Regards
Rob
Fusion
