seth.madore
in reply to: ltomuta
2D Chamfer will machine any edge that is selected, and avoid vertical walls or any other gouge. That said, things get a bit more tricky when fixtures are thrown into the mix. You can use the "Model" selection in the toolpath to also include fixtures, and it should pick those up:
Seth Madore
