12-17-2019
05:58 AM
- Mute
- Permalink
- Report
12-17-2019
05:58 AM
try to disable lead-in and lead-out arcs in linking tab (set them 0 or better uncheck all lead params)
or uncheck smoothing
then look, how it works now in mach3
also mach3 have a simulate pass function in 3rd tab from left
if issue remains then try to adjust arc parametrs in postprocessor dialog
try to change : radius arcs,allow helical moves,maximum circ radius, minimum circ radius
if it not works you can check end edit your toolpath with cimco edit or similiar cnc editor
Fusion
