doug
302 Views, 4 Replies
Chamfer tool path changes based on where my zero is located
Not really sure where this belongs but i need help.  When my zero is moved i get a different result for my chamfer tool path.  I had this done before the last update and now i made a change and updated my tool paths and i see what is in the -2 jpg.  Any help on what i am doing wrong would be greatly appreciated.
seth.madore
in reply to: doug
Well.....that's not supposed to be happening :thinking_face:
Can you share the file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
doug
in reply to: doug
I was thinking the same thing.  Attached is the file.
seth.madore
in reply to: doug
For the jagged toolpath, open up your tolerance (in the toolpath) to .003". I haven't seen it need to go out that much in a long time. I'll make a note of looking at this file deeper as soon as some time opens up for me
Seth Madore
doug
in reply to: seth.madore
That worked.  I was also able to get the tool path to work if i move the hole in from the edge of the part also, but that wasn't a solution i could use.  Thank you for your help.
