- Mute
- Permalink
- Report
I used Notepad++ to modify my posts, at first I modified Doosan post to run with Yama Seiki lathe having only C axis.
If you set that post for Lynx in user configuration window, it will not post any Y axis moves.
The reason why I modified it is to have all M codes adjusted to Yama.
In recent days I modified Nakamura post because it has updated section to support canned cycles and it doesn't use P codes for spindle selection like Doosan post does.
So far I was able to manage my needs with post editing but it is not so simple to instruct someone else without having more information on hand.
Can you upload specific post you are trying to modify ?, that would give me or anyone else chance to test it after editing.
You also need to program work in such manor that does not require Y axis moves, or post will fail.
Fusion
