10-28-2019
06:03 PM
- Mute
- Permalink
- Report
10-28-2019
06:03 PM
Cam Patch help
I have a cavity that I need to machine in 2 separate setups (G54 top and G55 side). How do I prevent the tool path from entering the side area in the top op and vice versa? I have tried patch with no success.
10-29-2019
12:07 PM
- Mute
- Permalink
- Report
10-29-2019
12:07 PM
It would be extremely helpful to see the file in question, even just a picture of it (actual file is much preferred)
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
10-29-2019
02:19 PM
- Mute
- Permalink
- Report
10-29-2019
02:27 PM
- Mute
- Permalink
- Report
10-29-2019
02:27 PM
Just set you bottom height on the heights tabs to [Selection] and pick a curve for how far you want it to go down.
10-29-2019
06:01 PM
- Mute
- Permalink
- Report
10-29-2019
06:01 PM
The problem I see with that solution is that I will still be machining into the G55 op .4" do to the different heights / angles of the two op two areas. Is there a way to patch these?
Fusion
