scottmoyse
in reply to: jeff.walters
@jeff.walters wrote:
The popup is set to fit on the screen so if the operation dialog is a bit off screen it will show above the selection.
It doesn't in a lot of cases... there are a lot of issues with the CAM tool tips in Fusion 360. The formatting is all over the place.
Also how they display is sensitive to screen resolution. They are far too big on my 2009 Macbook Pro.
There is an issue with the cycle type drop-down in the Drilling operation as well. The tooltip displays if you expand the drop-down, but it flashes up partially then disappears completely (as the OP described).
I see these issues in Windows (single & multi monitor setup) and OSx (single monitor).
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
