348 Views, 1 Reply
lathe g code not generating
i cannot get fusion 360 to generate a g code thru brackets using a lathe mode. i does mill code fine. this is a school other computers have 360 on them and works fine. it says turret number must be 0 (main turret)
seth.madore
It's not a Brackets issue, it's a tool library issue. You need to set the Turret number (in the library, that tool specifically) to the correct value. In this case, it looks like it needs to be set to zero:
Seth Madore
