johnswetz1982
in reply to: suzuki6327
That is because your entire part is off axis. I can get the first 2 to generate but can get the drill holes to generate because the way you have the part oriented would require a 5th axis move to get aligned. If you were to align your part I think you would have better luck. You were doing the right things it seems but with your part rotated that way and no design history you cannot put out solely 4th axis moves.
