- Mute
- Permalink
- Report
The error description and the line causing it are in the above picture.
I am told that it is caused by an arc command who's end points are not equidistant from the arc center.
According to a youtube from carbide 3D this is fixed using the latest downloaded post from the autodesk posts library.
I have downloaded that and rerun the tool path but I get the same error. Unfortunately the g-code file is 97000+ lines long and the error occurs around 80000 lines so it takes 25 minutes of CHECK run time before it finds it.
CARBIDE 3D youtube about this error
In the autodesk posts library there is a GRBL post for carbide 3D and one of the comments states
| 11/21/2018 | The ending location an arc is now adjusted to lie exactly on the circle. |
I do not see this note in the generic GRBL post.
Can I get that code included?
Can I run a generic GRBL machine using the Carbide 3D post?
Fusion
