in reply to: mrfamellas
After every update of Fusion, I like to program a job to see if there are any changes that effect the way I do things.
In this case I noticed that in order to be able to profile from outside to inside, you have to turn on "Allow Radial grooving".
This is known old bug that has not yet been fixed.
Posted fine using DS30SSY.cps
I haven't exactly followed my layout in earlier post but that's the nature of the beast, some things become evident
as you progress thru work flow and realize you need to adjust original strategy.
Some tweaking may be in order depending on material in question, use at your own risk.
