- Mute
- Permalink
- Report
Is there a way to "lock" or set a default for the toolpath setting panel size? In the image below the panel is "collapsed" so I need to scroll which causes my part to zoom in.
I would like to have all toolpath setting panels to open up like the screen shot below. Currently my work around to make the panel extend for the full height of the screen is to "re-dock" the panel. So is there a way to make the height default or locked for every time I open a toolpath panel?
Also is there a way to make the panels default to the above layout even on program start up? I currently need to re-dock all of the panels in my preferred way every time I start the program.
- Mute
- Permalink
- Report
Yeah...this is an annoying one. I just kept going up in monitor size until I had most of what I wanted in view. Certainly not the most affordable solution...
I've pinged the UX team for this, I'll let you know if I have anything better to offer.
Seth Madore
- Mute
- Permalink
- Report
Panels seem to only resize correctly if they are docked to the right side screen. This is a long time bug in Fusion's UI, disappointing they didn't address this before or while introducing the new UI.
Mark
Mark Hughes
Owner, Hughes Tooling
Fusion
