Its been a while but IIRC I'm using the Bridgeport post file that came with the software along with a couple minor changes. I've attached the one I'm using.
I followed the instructions in the Operators Manual for setting WCS (Appendix C) at the machine and when entering G55 for the new XY location the machine throws the same "invalid Gcode" error.
So it does seem that only the Bridgeport Machining centers have WCS capability.
I've made a few parts using fusion360 and this machine. I've always separated ops as an individual programs but those were 1 off parts. I'm now into production and don't want to setup op1 - 100 parts. Then setup for op2 - 100 parts, op 3 setup etc.. only to find out in the end that I made a mistake during op 3 and have to start all over again. I could run through all the setups once to make sure its a good part and then start with op 1.
I'm going to search for DX32 Machining Center software.
Thanks for your help.
I enjoy using fusion360 with an ancient machine.
