- Mute
- Permalink
- Report
A cursory reading of this seems to indicate that the G97XxxYxx values are the difference between one WCS and the next, and are incremental in nature. So, in order for that to be handled by Fusion, you would have to know those distances AND model up your work as such. Possibly more work than it's worth. I'd suggest having it put out G97X0Y0. and manually adjusting it at the control, once you know the distance from your first WCS system to the next. It doesn't appear that there is any limit on how many times you can do this, so it will take some experimentation to figure out how far you can push it
-EDIT- And I'm assuming that you are using the post that's found here? It appears that the output code is wrong, based on my reading of the manual....
Seth Madore
Fusion
