safiredesignengineers
281 Views, 1 Reply
fusion 360 milling stratagy into and out of corners
hey group! on fusion 360 milling does the cam sort de-acceleration into corners and acceleration out of corners?
this would be for running the posted file on a prototrak machine which has no look ahead facilities on it so basically the cutters just slams into the corners and out again.
There are some toolpaths such as 2D Contour and Pocket that do have "Feed Optimization" that will decrease feedrates in corners (2D/3D Adaptive also have it, but you won't be using those on a Proto mill)
Be warned though; it's slightly broken, in that "Only Inner Corners" does nothing, and you may end up with outside corners also being slowed down if your parameters are set "just right".
To use this feature on the Passes tab, take note of the wording: Minimum radius allowed. You want that value to be greater than the radius being swung by the tool through the corner.
Seth Madore
