in reply to: CAMXPRESS
The task of generating tool path takes about 5 minutes, took a lot longer to explain it, I see some threads resurfacing back months after solution was found for original issue.
I start every project with dose of suspicion, ....what if I do this or that, what's the most effective way?... in time some things become routine, you may skip over bug without knowing or discover one by accident so I think key is in  experimenting.
I have some parts to do where customer yanked components out of assembly and left them in arbitrary position, no matter what plain I pick, part is always in some odd position.
Then I thought, what if I make a new body on  one of the planes, make components, assemble two parts and then delete one I no longer need,.......... fixed the problem of guessing where to rotate part or by how many degrees.
So some things are not crystal clear but there is always some way around obstacles, just another day here.
