in reply to: CAMXPRESS
@CAMXPRESS wrote:
Hello VicKosta,
You are lucky at this time with the automatic profile generation.
The question is how to use your manual method at this time if the automatic spun profile is wrong?
(I only like to learn tricks and do not like to overload you my questions.)
Joe
Actually, wrong again, I was not lucky, I took a close look at model from every perspective then generated sketch and made sure turning tool does not violate any section of the model.
Because I am convinced that spun profile has something to do with using part profile and spinning it around Z axis for purpose of determining boundaries for turning tool when model is not round or symmetrical, I can create such profile that outlines boundaries of my choice.
Without that profile you have nothing, putting check mark in "spun profile" box on setup tab does not automatically generate result out of thin air.
If future development makes that possible it would be very useful, but for now, I think it's tool that requires user interaction.
If this is not how it works, I welcome more in depth explanation from people who created Fusion, meanwhile, my way gets things done for me.
Vic
