in reply to: CAMXPRESS
@CAMXPRESS wrote:
Hello VicKosta,
Thank you for the reply. Your solution only work if the base part is a revolved part.
If I made the top "pyramidic" boss extruding a scetch and after draft the sides, yo do not
have information about the revolution profile.
The spun profile needs to work independently the way of the part design.
Joe
I respectfully disagree;
If it doesn't exist, make a sketch or project profile of section, select as turning geometry, it works, it's in the title,.......... "spun profile".
I don't dispute lock of features and refinements in turning, but in this case, "the only solution that works" is the only solution I need.
I noted that customer supplied models don't have any sketches so I create it if I need it.
It works for me while Fusion works on the "other" solution, I made dozens upon dozens of parts with this impairment.
It may have to be dependent on main body because it needs to match part of its configuration, perhaps in form of hidden, duplicate body or automated sketch produced by additional menu that triggers its creation.
I can machine parts using existing solution or refuse to do so while waiting for "real" solution, the choice should be obvious.
