coryharris323
659 Views, 13 Replies
simultaneous machining haas 4 axis
hi gurus out there i am trying to get my pre ngc VF4 haas to simultaneously Machine a part which is basically just a drill head. The problem i am having is the tool path seem to not be anything like the path i have generated in fusion 360 instead of rotating the a axis and feeding along the X axis the program seems to  move across the Y axis while moving  in the Z axis . I have hopefully attached the right screenshots and fusion 360 export so you can see the paths im trying to create
cheers
Cory
