campbellqn
475 Views, 5 Replies
Bore Order By Depth
I believe Ive found a bug in the bore operation. I have a plate that needs a series of bores and counterbores. When I select counter bore (larger hole towards to the top) and the main bore the operation is fine, but as soon as I add select all same diameter it starts with the inside (lower hole) resulting in a rapid collision.
