- Mute
- Permalink
- Report
tapping with f360
Hello all,
i have always had an issue tapping with fusion. most likely im not using the dwell feature properly, or this could possibly be a post processor issue, not to sure yet.
basically any and every time i try to tap a hole with f360 it taps perfectly until it gets to the bottom of the hole..
from what i can tell the dwell and spindle rotation don't seem to be sync'd. it would appear that the spindle stops for the dwell, but starts its exit in z axis before it ever reverses. meaning that during the dwell period it actually only stops the spindle rotation not the z axis. amazingly enough i have probably tapped 50 holes or so this way and never even broke a tap. i've actually had taps come out of the holders and stay in the part, but haven't broken a tap.
usually i just skip the tapping anymore and do them at a manual mill(not much production work here luckily).
does anyone have a solution to this? im pretty positive im just not checking a box or turning a feature on, but i could be wrong.
Fusion
