in reply to: seth.madore
Hi Seth
I think I've mostly eliminated the chance of it being mechanical (but will try the cutting air test anyway). There's no limit switches on the machine yet so I can't home it as such (I just manually position then zero out work coordinates).
Jobs seem to actually execute perfectly - I've measured the results. It's just the return to zero thing means I struggle to run a second toolpath accurately. Other sources of G-Code - of arbitrary complexity - don't seem to exhibit this behaviour - it is specific to Fusion.
Thanks for the reply - and I'll keep plugging away!
