seth.madore
I am somewhat skeptical that it's Fusion. I'm not saying that because I work for Autodesk, but mostly because every time this sort of issue arises, it ends up coming back to machine/control side.
What happens if you re-home your machine and run the code again? If it's cutting air the entire time and still does not return home, we are going to look into other areas. Are all set screws tight? Are all mechanicals absolutely secure? Is it losing steps due to some very small fast movements that are being skipped over?
Seth Madore
