seth.madore
You can ask as many questions as you want :slightly_smiling_face:
To cut on the outside, your easiest method is to turn off your sketch and make the selections on the model. When both model and sketch are turned on, 9 times out of 10 it will select the sketch
For tooling, I'd suggest a flat endmill or "bull" endmill that has a small radius for strength. Assuming this is wood or plastic, sharp corner will be fine.
Seth Madore
