06-16-2019
11:40 PM
- Mute
- Permalink
- Report
06-16-2019
11:40 PM
Siemens 'c' axis issues
Hi All, I'm looking for advice again!
I'm running a simulteaneous 4 axis pocket job using the C axis on a SMEC lathe with Siemens 828. The part runs perfectly on the simulation. The code is running fine until the value for 'C' changes from 1.154 degrees to 359.987 degrees. The machine will go the longway round instead of the shortest route. At this point the cutter is still engaged in the part!!
Is there any way that angles can be outputted incrementally or does anyone know if there is a parameter in Siemens to make sure the spindle goes the shortest route?
N1135 Z-93.665 C=2.746
N1136 Z-94.701 C=1.154
N1137 Z-95.804 C=359.987
N1138 Z-96.922 C=359.091
Any help is greatly appreciated!
Chris
Fusion
