- Mute
- Permalink
- Report
I would like the toolpath direction to be changed by 90 degrees in a contour operation. I think I found a setting in the past but can not remember what it was. Please help.
Thank you.
- Mute
- Permalink
- Report
Are you talking about a start point or something else? A visual of what you are referring to would be very helpful
Seth Madore
- Mute
- Permalink
- Report
Seth,
Sorry for the delay in answering I was traveling. Not the starting point. Say the cutting direction is following the X axis back and forth but I want it to follow the Y axis back and forth. Most parts Fusion picks the correct direction but occasionally I want to go the other way.
Any suggestions?
Thanks Alan.
- Mute
- Permalink
- Report
Thank you. I must be missing something. In the passes tab I see a "Direction" box but I can only select "climb" "conventional or "both ways".
Any ideas?
Fusion
