Have a look at flow it does a better toolpath with a 1mm ball mill than the endmill in your toolpath, I set the angle to 25 degrees for the max tilt and only this one with an angle and the WCS top dead center.
They have done a lot to the flow toolpath lately it's the, not 100% yet stuff but it seems A round surface will only do 4 axes if you find the sweet spot for the max tilt angle. for your model that seems to be 25 degrees.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
