in reply to: johnswetz1982
Thanks again for your help.
I was able to create multiple construction planes although difficult at times to get the correct orientation especially if the object has curved linear surfaces.  Also I created an hexagon and attached it to the end of the part and used each side as a manufacturing plane.  That worked well also.  I did have to create a separate set up for each face to machine so I will have to see if I can combine these operations into one gcode.  I don't think fusion 360 will write an Ax code to rotate the part but I could always add that in myself if it will generate the complete code.
I'll have to work at creating construction planes a bit as there is a lot to it.
Any further insights are appreciated.
Once again, thanks for your help.
