johnswetz1982
You can either create a model of your stock much like you model a piece. If it has 6 or 8 or 12 sides. Have that as its own file, then insert it into your piece design model file and use that as a stock selection under setup. You can also use the [Construct] menu to construct plane at an angle. Or you can do a combination of both. This will give you the selections needed for setting tool orientation under an operation setup.
