- Mute
- Permalink
- Report
@engineguy @Anonymous thanks for the replies guys.
I can't post the actual part but I can post something similar I played with to see if it was possible. The area of the part I'm trying to machine is practically the inside of a tube. If you take the picture you have posted there @VicKosta, and basically flip the plunge lines to the inside of the part that's what I want to do. But it is just one face. As the floor is flat in cross section I can't use it as an axis for the wrap. I have tried using the inside of the path i made the "spiral" with but to no avail
I can program it easily with the conversational on the machine but I won't be back near the machine until Tuesday and of like to get the quote off Monday (also there's no doubting fusion will be faster). The whole path looks perfect it's just machining it on the outside surface of the face and I want it on the inside surface.
Thanks again for your time.
Fusion
