04-27-2019
07:15 AM
- Mute
- Permalink
- Report
04-27-2019
07:15 AM
Are you using the bottom of the pocket radius for the "wrap" or are you using the outside radius, if using the outside radius and an offset for the depth then it does appear to do the toolpath from below.
Select the bottom of the pocket for the depth and also select the radius in the bottom of the pocket as your "wrap", seems to work here, attached is a small example that works OK here so have a look and compare it against what you have.
If it isn`t of use to you then export your Fusion file to your PC and attach it to your reply and someone can have a look at it for you.
Regards
Rob
Fusion
