tbiggerstaff3H7FS
326 Views, 5 Replies
3D machining a pocket
Hello , new to fusion 360. Wanted to see if I could get some help with this 3D machining of this part. Tried some different ways to get this done. Could you take a look to see if I'm programming this correctly or if I need to be surface milling this differently.
Thank you for your help,
Tony
It's not bad, but I would likely opt to use the Scallop toolpath, it just does such a nice job:
You are over complicating your selections. For the image above, all I did was select the top rim and define my heights
Top Height = Model Top
Bottom Height = Model Bottom
Seth Madore
Hey Seth thanks for getting back to me. Are you speaking of doing a
scalloping on all the surfaces? I appreciate you help and feed back .Just
let me know and I'll go the route you suggested. Trying to learn this
fusion 360 little different from featurecam that I used before hand.
Thanks again for your help
Tony Biggerstaff
I would say that it does depend on the surface finish requirement and quantity required. Scallop CAN take a bit longer to run than, say, a Parallel strategy. The plus side is that selection is easy and it just does a thorough job.
Yes, Fusion is certainly it's own breed..
Welcome to the community!
Seth Madore
Hey Seth, thank you sir for your help , will go with the scalloping
surfacing and hope all goes well.
Have a good day.
Tony Biggerstaff
Best of luck, and don't hesitate to come back if you have any issues.
Seth Madore
