in reply to: seth.madore
initially seeming to be correct. i checked a file that had the correct output in the "nc programs" "order by tool" that had the expected output prior to the update. re numbering the tools and re generating all operations. i seem to have the same behavior as described previously even with all different tool numbers. see attached. i understand this feature is beta. but something would appear to have changed. See attached file with issue. and photo of tedious work around.
