271 Views, 1 Reply
rest machining doesn´t work properly
after last update rest machining doesn´t work properly. Before I was using it regularly and it worked well. Now fusion cannot compute toolpath if rest machining is checked. I am including pictures of toolpath before and after update.afterafterbeforebefore
I have no idea how to fix it. I checked all parameters several times and everything is same as before update so there is no reason why the toolpath cannot be calculated.
Tags (1)
